Gaszug mit Reibungseinstellung
Zubehör wie Instrumente, Motoren, Räder, Bespannmaterial etc.
Gaszug für Flugzeuge
mit Festellbremse
Länge 3 ft, ca 1 m
Throttle friction control, P/N A-800 3ft, black knob.
Neu, mit Originalrechnung vom 06.10.2016 und Certificate.
Aircraft Spruce Part Number:05-08636
Zollgewindel für Anschlussgabel zum Vergaser: 10-32 (ca. 4,8 mm Außendurchmesser)
The A-800 friction lock control provides positive locking at any power setting by turning the chrome collet locking nut. Unique ball-socket construction permits 10-32 threaded end to swivel 8 degree in any direction. Casing has Teflon liner for low friction and heat resistance in high-temperature areas such as engine compartments. Travel: 3-3/8". The 1-1/4" dia. solid knob is available in black or blue (blue knob has smooth profile, not FAA style). Stocked in following lengths (measurement taken from under panel nut to end of threaded shaft with knob pushed in).
Hermann Thissen
thissen.h@web.de
Telefon: +4915156372953
